‎08-16-2017 02:12 AM
I am having the same problem. But this issue occurs with each files and projects that I want to open.
Sometimes I also couldn't find the right .vi / .llb/ .lib in the folders. I tried to reinstall whole LabView 2013, but this hasn't work either.
Does anyone has another suggestion?
‎08-16-2017 02:33 PM
Do you have a cRIO project, and if so do you have the real-time module? Did you try reinstalling this module? Also, I would suggest making a new post since this one has already been marked as solved.
‎08-16-2017 03:03 PM
Note: Split from previously solved topic involving a missing LabVIEW RT Module
Can you provide screenshots of the project Files View?
‎08-23-2017 10:49 PM
Hello guys,
I have solved the problem with the repair tool of LabVIEW itself. Afterwards everything worked well again.
