Can you access the LabVIEW FPGA constraint files?
This question was presented to me by a Verilog designer who will be using LabVIEW FPGA to run their Verilog code.
ALE Consultants
(3,012 Views)
Depending on what you are looking for, you might be able to find them under C:\Program Files (x86)\National Instruments\LabVIEW 20xx\Targets\NI\FPGA\RIO\CompactRIO\cRIO-90xx\cRIO-90xx\VHDL.
(2,945 Views)
If you are using LabVIEW 2017 and a FlexRIO module, you can export the whole thing over to Vivado if you want.
http://zone.ni.com/reference/en-XX/help/371599N-01/lvfpgahelp/export_fpga_vis_howto/
(2,936 Views)
