Radio control
Suppose I want to use a boolean/radio control in the front panel in order to activate certain inputs i.e. if radio has a certain value then I need to enter a set of inputs and if radio has some other value then I need to enter a different set of inputs. For example, consider a radio control having values "BUS" and "MOUNTAIN". If BUS is chosen, then the inputs given should be mileage, speed, etc. and if MOUNTAIN is chosen, then inputs that need to be given should be height, etc. How can this be implemented in LABVIEW?
(2,673 Views)
Accepted by Dhiraj072
Hope this will answer. Let me know if this answers
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,666 Views)
It helped. Thanx a lot 🙂 !!!
(2,632 Views)
