DAQmx Error 200547
For one of my projects, I created a calibration routine that will allow me to calibrate a vibration tables amplitude to a user defined value. The .jpg that I attached to this post will loop until the value of the shared variable is 1.8 then it will exit the loop. In this case, I am increasing the amplitude all the way up to 1.8 however, I would also like to perform this operation for multiple frequencies. I inserted this routine into a while loop hoping that every time the amplitude is 1.8 it will exit the local while loop, increase the frequency value then keep doing this until a user defined frequency is attained. The issue that I am faced with is that every time I exit the main loop, the error 200547 appears. I tried different suggestions that were posted on the ni forums concerning this issue however, I could not resolve the problem.
Any suggestions would be greatly appreciated.
(3,159 Views)
The error has to do with an onboard write buffer overflow. You are adding to the write buffer faster than you are sampling. I would add some wait time to the loop that contains the write vi or I would try to increase the rate that your AO is running at.
TimC
(3,119 Views)
