RTSI implemention between FPGA and PXI controller
I have a need to be able to send and receive data from a r-series modules. I note these have an RTSI bus (PXI form). I am looking to implement this bus so I can pass results to a PXI controller and send new settings (info for PWM), can someone point me at an article as I have been looking for a while now to no avail.
Many thanks
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,245 Views)
To pass data from an FPGA depending on the data type it is common to use a FIFO as R series cards tend to gather data faster than most devices can handle so the buffer is used so data isnt lost. If you could post some example code I would be happy to point you in the right direction.
Matthew Trott
National Instruments UK
www.ni.com/ask
(2,231 Views)
