64-Bit Labview Vision Acquisition
I am currently in the process of upgrading from LabVIEW 7.1 to LabVIEW 2011. I have been able to get everything working with LabVIEW 2011 (32-Bit). I have installed the Vision Acquisition and all works well with LabVIEW 2011 (32-Bit). When I try to use the LabVIEW 2011 (64-Bit) I no longer have the Sub Vis that are in the Vision and Motion Pallet. I was wondering if the LabVIEW 2011 (64-bit) needs an additional download in order to allow my Vision Acquisition toolbox to work.
FChiragh
(3,334 Views)
I had the same problem last week.
I had to uninstall Vision and IMAQdx and then re-install them.
http://www.medicollector.com
(3,319 Views)
I'm having trouble uninstalling it. How do I go about doing that?
(3,313 Views)
Go to:
START > Control Panel > Programs & Features
Then double-click on "National Instruments Software" and remove everything related to Vision and IMAQ.
Then reboot your PC.  And then reinstall it.
When you reinstall it, make sure the installer indicates that the software will be installed to "C:\Program Files\..." and not "C:\Program Files(x86)\..."
(3,309 Views)
Works now! Thanks!
(3,297 Views)
