RT
Hi
Iam using PXIe 8135 RT controller.Iam facing a peculiar problem.I am setting
etho primary adapter(static ip)=192.168.3.88
subnet=255.255.255.0
eth1  adapter(static ip)=192.168.6.88
Sometimes after powering on the system eth0 gets disabled and eth1 becomes primary.Screeshot attached.
ekanth
(3,327 Views)
I am having a similar issue. I have a number of PXIe-8135 controllers configured with a static IP address on port 1, with port 2 disabled. Every once in a while, after a power outage, the controller restarts with port 2 primary and configured with the static IP address that had been assigned to port 1. How can this be prevented?
(2,743 Views)
