RE: Print a front panel in a file
Use a pdf printer driver and use this along with the print on completion
setting for the VI that you want to print to file.
This is great for reports.
> -----Original Message-----
> From: comp.lang.labview@omigatech.co.uk
> [mailto:comp.lang.labview@omigatech.co.uk]On Behalf Of Cesar
> Sent: 03 December 2001 12:03
> To: comp.lang.labview@omigatech.co.uk
> Subject: Print a front panel in a file
> I would like to know if there is any function or other way to print a
> front panel in a file (a picture file or a print file) in execution
> mode.
> thanks
(2,641 Views)
I'm not aware of a single vi that can do this. The way I've done this is to use combination of vi's described under Help in "report generation vis and function" located under "vi and function reference."
(2,641 Views)
