To accomplish the first task use a control button, a case structure and a sub vi located inside the case structure. The control button determines the status of the case structure in response to user click. The sub vi writes your data into the file you specified in the file dialog. The entire process repeat itself each time the button is clicked. The set-up of the sub vi depends on organization and type of file you want. I think the second task is just a modification of the first.
