RAS NW Auto Dialup
I need to start a dialup RAS Connection programmatically by a LV
program. It seems there's no LV tool with this capability.
Any ideas would be of great help.
Holger
(3,655 Views)
If you simply want to establish a TCP/IP dial-up connection the
standard Win98 type dialer should automatically load when you do a
TCP/IP open - it seems to wait ok until the connection is established
- can be a bit difficult to programmatically close.
Another option is that a number of the DUN alternatives allow for
command line operation (e.g. Advanced Dialer) - this can be useful for
closing the session. I have found that it is best not to invoke the
dialer programmatically but rather let the TCP/IP open cause an auto
connect - this seems to cause less problems with timeouts.
Donald
dlove@paradise.net.nz
On Mon, 23 Aug 1999 13:49:02 +0200, Holger
>program.
>Thanks
>Holger
(3,655 Views)
