06-02-2009 09:55 AM
06-02-2009 10:23 AM
Please do not embed images inside of RTD files and then put them inside of zip files. You can save screenshots as PNG which makes them really small and upload them directly. ![]()
With respect to your code: You have highlighting on, and it clearly shows that the array of reference being fed to the Search 1D Array function is empty, so there's nothing to find. I don't understand what your problem is. Can you provide more information?
06-02-2009 10:45 AM
Hmmmm...kay. Guess I didn't realize it was empty, versus being a single element array with it's only element being "0". In that case, I'm not sure why the array is empty.
First, some context: I have a LeCroy LSA1000 analyzer/digitizer that I can't read/write from, as something goofy is going on with the TCP VI's. I noticed when running some of the VI's contained within the tcp_instr library for the LSA1000 (obtained from NI's driver net) that an error is produced in any VI's using the tcp_Registry.vi. Sooo, I'm trying to understand what this vi is doing, and see that the problem occurs at this Search 1D Array function, since the element can't be found in the input array. However, I'm not sure what the input array should contain, or how the tcp session part affects this....
06-02-2009 05:44 PM
When you're in highlight mode the little yellow tooltip that appears over wires will tell you the value in case of scalars, and the number of elements in case of arrays. The "#0" indicates an empty array.
As far as the drivers are concerned: They seem to use the TCP/IP VIs instead of VISA. I don't know why, but there you go. The "TCP Registry" VI is just an Action Engine. It keeps track of open connections in case you're connecting to more than one LSA1000. Not sure why it was written that way, but there you go. What error are you seeing? The most likely error you're seeing is the "invalid object" error which is due to not having a session registered. Which VIs from the instrument driver are you using? Does the "LCLSA Initialize" work? Can you upload your code? Have you verified that you can ping the instrument on the network?
06-03-2009 07:48 AM
Thanks for that info! You are correct that the error I'm getting is that invalid object error. I get this error is I run the tcp_Register.vi by itself, or if I run any other vi in the library that uses the tcp_Registry.vi. I haven't used any of my own codes yet as I can't get this driver/library of codes for the LSA1000 to work yet, and I need to use them as a part of my main project. I can indeed contact the instrument via pinging at 172.25.1.2.
The "LCLSA Initialize" vi does work.
06-03-2009 08:22 AM
I was a bit surprised this morning by the fact that the Initialize vi worked, so I decided, "What the heck?" I'll try the "LCLSA Wave Save To File.vi" again, as I haven't been able to get this one working without errors for the past few months. And, magically, it worked! I didn't believe it, so I ran it again - and it worked again! I still didn't think this was true, so I ran a slightly modified vi I made, "LCLSA Wave Save To File_looped.vi", which just repeats the vi for multiple iterations to create multiple data files. And this worked, too! I have NO idea why today everything seems to be fine - I've seriously had issues with the stuff for at least 3 months. However, I'm just going to go with the flow and see if I can now implement this stuff in my own application now and will let you know how that goes.
A quick question - do you have any suggestions as to how to view the data files properly? I believe they come out as binary, but look like mumbo-jumbo when viewed in a text editor like WordPad. Thanks!
06-03-2009 08:37 AM
06-03-2009 08:40 AM - edited 06-03-2009 08:46 AM
The "tcp Registry" VI is not meant to be used directly. It's designed to be used as a subVI. You need to provide a valid TCP session and that's only available when your program is running. Once your program stops and there are no VIs running there are also no valid VISA TCP/IP sessions. For application code you should only be using the VIs in the "lclsa" LLB.
As for reading the files: Those are binary files. The "LCLSA Wave Save To File" writes out some request commands and then reads the binary data from the instrument and saves it to file. The exact format of the data should be defined in the user manual, but it appears to have some header information and then the waveform data. The file sizes look awfully small, though. Basically you would need to use Read From Binary File to read the saved files and interpret the sequence of bytes based on what the manual says. If you're not sure how to do this, please upload the snippet from the programming manual that discusses the format of this data.
06-03-2009 08:42 AM
nellium wrote:
Alright, I've found something that doesn't work. When I run the "LCLSA Application Example" vi, I get that "invalid object" error right away when the sub-vi "LCLSA Vertical Setup" calls the "tcp_Instr_Write" vi. Any idea why I'd get the error here, but didn't get it when running the Initialize vi or the "LCLSA Wave Save To File" vi before?
The "LCLSA Application Example" is not designed to be run on its own. It expects a valid TCP/IP session, and that only happens when you run the Initialize function. Look at the way the "Getting Started" VI is done.
06-03-2009 08:45 AM
First, you rock. Thanks for helping me understand the intricacies of how this stuff all works, I really appreciate it.
Second, the user's manual is conveniently still on the web:
http://www.lecroy.com/tm/library/manuals/LSA1000RM/RemoteControlManual/LSA_RCM_Rev_C.pdf
