Python Node in LV2018
Okay, and i try reinstalling the LabVIEW, then i find everything is ok. It works well. However, something still confuse me. When i use Python integrate toolkit, function call and module import can be divided. However, the Python node can't.
Message 31 of 41
(6,552 Views)
Hi Aurelien,
Thanks for the comprehensive guide. The python node amd ML libraries are working fine together.
I'm creating a python function that defines a deep learning model and load pretrained weights in it, and returns the loaded model. However, we need to specify the 'return type' in the python node, but LabVIEW only supports numeric, string, boolean, and clusters as "return data type", and the model's datatype doesn't fit under any of the supported types. When I check the datatype of model in python, it shows 'tflearn.models.dnn.DNN'. Is there anyway to define a custom return type in python node? or any other way to get around this problem?
On the other hand, when I define a python function which loads the weights into the model and then make prediction on a test example, the return variable is an array of predictions whose return type is an array of float32, which is supported by python node. Hence, this works well. The downside to this is that every time this python node runs in a loop, it loads the weights into the model from scratch and then makes prediction, which is quite a time extensive process.
To avoid reloading the weights every time, I planned to define a separate function outside the loop for loading the model only once , and another function inside the loop for making predictions only using the preloaded model. However, due to the ambiguity in specifying the return type of the loaded model in python node, i'm unable to execute it.
Any suggestions and help would be greatly appreciated. Thanks
Message 32 of 41
(6,492 Views)
can someone down convert from 2018 to 2015. thank you
Message 33 of 41
(6,366 Views)
Hi Chuck, the python node was introduced in LabVIEW 2018.
Message 34 of 41
(6,359 Views)
Hi Chad,
Whenever I try to use any python packages such as numpy, I get a "ModuleNotFoundError: No module named 'numpy'" error. However, I have numpy installed and my path variables are properly defined. I got the same error when I tried to run your example. But, your program runs perfectly fine from python shell.
I am using python 3.6.1 on a windows 8 machine and I don't have any other version installed.
Thanks in advance.
-theAtom
Message 35 of 41
(6,176 Views)
Hi Theatom,
Do you have anaconda installed ?
are you running labview 32 bits or 64 bits ?
Did you install Python 3.6-32bits or Python 3.6-64bits ?
Did you try to follow this steps :
1. in the command prompt write "cd C:\Users\user\AppData\Python36-32\Scripts" so all the other command will occur in this folder.
2. type "pip install numpy" and the other libraries that you want.
Message 36 of 41
(6,165 Views)
Hi Chad,
I do not have anaconda installed.
I am running both LabView and python3.6.1 in 32 bits.
And my python installation path is c:\python36
If I try to install numpy, I get a message "Requirement already satisfied". I have attached a screenshot.
Regards.
theAtom
Message 37 of 41
(6,140 Views)
It's probably worth checking that the python that LabVIEW finds is the one that you're expecting and that there isn't another dll further up the system path that's been installed by some other application. The snippet attached will query where the site package directories are - you can then check that numpy is actually installed in there.
(It's remarkably difficult to use the Python node if you don't know what the sys.path looks like, and it's tricky to use the Python nodes to tell you what sys.path is if you don't know it already!)
Gavin Burnell
Condensed Matter Physics Group, University of Leeds, UK
http://www.stoner.leeds.ac.uk/
Message 38 of 41
(6,121 Views)
Did you try to uninstall python and reinstall it in the default directory and check the box "add Python36 to Path" ?
I made a test by installing Python 3.6.8rc1 and run the example PythonNode_AddTwoDoubles.vi, all works perfectly.
My default directory is : C:\Users\"name of user"\AppData\Local\Programs\Python\Python36-32
If there is no error running the example then you should try to install the module numpy in C:\Users\"name of user"\AppData\Local\Programs\Python\Python36-32\Scripts then run your code.
Message 39 of 41
(6,109 Views)
To anyone finding cheriks's example of the Python node now (>=9/2020), I stumbled for a while on making multiple figures in matplotlib using the backend agg, with Labview.  I was calling plt.figure(1), plt.figure(2), etc.  It worked in Python on its own, but threw an error in labview.  To solve the error, after "import matplotlb.pyplot as plt" add the line "plt.ioff()".  Then it works fine to call plt.figure(x).
Message 40 of 41
(5,903 Views)
