Put 2 elements in a Table
I am guessing that you need a solution quickly.  Delete the bad wires and create an indicator.  Let us know if the indicator matches your expectations.
Message 11 of 25
(2,638 Views)
I tried what you say the indicator....and I need a quickly solution :S
But I want the table.. because the indicator I couldn't tried if it's works the same as the table.
Srry for my english and sometimes I couldn't undertood so good because I'm learning too.
thanks
Message 12 of 25
(2,633 Views)
Accepted by jocuma
Now wire the first build array into the second.
Change the empty array constant that initializes the shift register from a double datatype to a string datatype.  Wire up to the table.  (And get rid of the double array indicator.)
Message 13 of 25
(2,629 Views)
Thanks a lot, now i give you a kudo,
can you pass me the link of the tutorials please?
thanks for the help 😄
Message 14 of 25
(2,622 Views)
Message 15 of 25
(2,619 Views)
 Hi Ravens,
One little question, why in the excel don't separate with two columns?
I use this.. http://zone.ni.com/devzone/cda/pub/p/id/1339
Message 16 of 25
(2,590 Views)
Your file opens up with data in 4 columns for me.  I looked at your raw .csv in notepad.  It appears to me that you might be using a comma as a decimal point rather than a true decimal point.  Is that so?
If so, then your "decimal comma" is being confused as separator since you are using a comma as a separator.
I'd recommend converting your numbers to strings using a decimal point.  Alternatively, you could use another separator besides a comma (perhaps a tab) when using the Write to Spreadsheet File VI.
Message 17 of 25
(2,582 Views)
No, the file opens data in One column I put you a picture about this, and I want to in two columns
The "Bad" picture is what happens now.
The "I want" Is what I want to do...
I tried different methods and this works better than the others but I don't know how to separate in two columns :S
Message 18 of 25
(2,579 Views)
Well, you still have that decimal comma problem to solve.  You can't use a comma as a delimiter if you are also using it as your decimal point.
The second problem is actually a problem with Excel.  If you just open up a text file in Excel, it makes an assumption as to what the delimiter is and how many columns to display.  I usually find that Excel guesses wrong.  If you open up a blank Excel sheet and Import the file in, it gives you a dialog box where you can go through and say it is delimited, and say the comma is the delimiter, then it will put it in separate columns.
After the fact, you can use Data menu, Text to Columns menu choice to convert what you have now into multiple columns.
If you can fix your number to string conversion to use a period for a decimal point, that will help a lot.
Perhaps you need to try to set the tab character as the delimiter.  You'll wind up with a "tab separated value" file rather than a "comma separated value" file.  But I think in this case, Excel makes a better guess on the default importing functions and will separate it into columns.
Message 19 of 25
(2,564 Views)
Yes I agree with you...I use the Tab (/t)
and pass the same as the coma and point.
"But I think in this case, Excel makes a better guess on the default importing functions and will separate it into columns"
I tried to do this with a property node with export to data from table and the result is bad because only takes the first row the fisrt column :S
Message 20 of 25
(2,558 Views)
