Adding lines on front panel
I was wondering how to add lines to my front panel of my Labview Program. Here is my front panel along with the lines that I want to put on the front panel of my vi
Message 1 of 10
(4,374 Views)
Are you saying that you want to graph some lines?
Bill
CLD
(Mid-Level minion.)
Message 2 of 10
(4,363 Views)
I have my VI going to an excel file where I can graph some lines but on the Front Panel I was wanting to add some graph lines where I would now exactly where my points where before I graph it in excel
Message 3 of 10
(4,351 Views)
Message 4 of 10
(4,351 Views)
Pretty vague.  Read the help for graphs so you can format your data into something the graph will like.  I think we could help you a lot more if you show us some code.  🙂
Bill
CLD
(Mid-Level minion.)
Message 5 of 10
(4,342 Views)
Here is my code
Message 6 of 10
(4,336 Views)
The purpose of the graph on the front panel is to show this?  It looks like you are graphing data...
Bill
CLD
(Mid-Level minion.)
Message 7 of 10
(4,323 Views)
Yes Im graphing data but I wanted to set lines on the front panel of the VI. So  when one runs the program they can see if the data stays within the specified lines.  I
Message 8 of 10
(4,318 Views)
Hello word 505,
If I understand your question correctly, you need to add reference lines to the graph itself, rather than plotting data- is that what you're looking for?
If that is the case, you can change the appearance of the background grid by right-clicking on the graph and going to Properties>>Scales>>Grid Style and Colors.  You can adjust the color and spacing of the X- and Y-axis major and minor grids here, the example you provided has them set to transparent/invisible.
Tom L.
Message 9 of 10
(4,305 Views)
Ahhh, limit lines!  Here's a search on limit lines.
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(4,304 Views)
