Property node for multiple labview controls
Hello I would like to make several control elements visible and invisible at once and wanted to ask if you can bundle them into a property node?
My Masterplan is to change the Frontpanal Completely .
Message 1 of 9
(5,138 Views)
You could build an array and then autoindex through a For loop over all of them.
That sounds like what you want to do.
GCentral
Message 2 of 9
(5,132 Views)
You can't. Possible alternatives:
a) create references from the controls and make arrays from them: you will be able to set properties in a loop
b) group your controls in clusters
Paolo
Message 3 of 9
(5,126 Views)
I used to do this all the time (I haven't done any GUI intensive applications for awhile).  It is definitely the way to go for the situation.
Message 4 of 9
(5,089 Views)
Thats not realy nice
because the elements don't disappear at the same time
Message 5 of 9
(5,084 Views)
Depending on the complexity of your GUI, it will look like the same time.  To really make sure, you can set the Defer Front Panel property to freeze the front panel before the loop and then unset it after the loop to make the front panel update.  Then all of the updates (values, properties) will draw at the same time.
Message 6 of 9
(5,078 Views)
How to create Defer Panel Updates Property?
Message 7 of 9
(5,069 Views)
I didn't see any variation when doing it on my laptop. If you have a lot of elements and a slow computer, then the DeferPanelUpdates property that Crossrulz beat me to is the answer here.
It will also likely make the process faster in general, which could be an additional benefit if you have so many operations/such a slow computer that it is a problem.
Edit: Note I said "see any variation". Of course in principle without the Defer Updates, there is some variation.
Re the property node, create a property node, read the Panel reference value, and then wire that to a second property node and select Defer Panel Updates.
If you wanted to do this from another VI, you can pass a VI reference to the first property node where you get the Panel reference.
GCentral
Message 8 of 9
(5,066 Views)
Message 9 of 9
(5,053 Views)
