Programming Laptop Wifi using Labview
Hi Dear TREX,
i am unable to understand how to detect Disconnection during Read Time out. Kindly help me in this.Thanks
awais qureshi
Message 11 of 21
(4,647 Views)
You can't unless the other side of the connection explicitly sends a TCP-RST or TCP-FIN. If neither of these are sent there is no way for the your TCP-Read to detect the connection has been closed. This is not an issue with LabVIEW but how the TCP protocol works.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 21
(4,640 Views)
can u tell me how to achieve BT communication from laptop for remote control of sbrio 9631.
Message 13 of 21
(4,497 Views)
Dear srabot,
BT VIs are available in Labview which may advertise laptop BT module using UUID. Also you need to uninstall any other OEM driver, only BT driver of Microsoft window is required to accomplish BT communication using BT VIs of LabView. Good example are available in Labview as very for making Laptop master or slave.
Good luck
Message 14 of 21
(4,488 Views)
hi Awais Qureshi
i am junior and i have many trouble when i start with labview
i have used tcp to connect pc-pc with utp capble but,do it as wifi,i cannot
so,can u tell how to use tcp make a wifi connection pc-pc
thanks so much
Message 15 of 21
(4,201 Views)
LabVIEW does not know the difference between wired and wireless ethernet.
Please start a new thread and provide more details on your network configurations.. For example are both computers on the same subnet? Can they ping each other?
Message 16 of 21
(4,196 Views)
thank for your care
with microsoft menthod,i can creat a  network by wifi(ad hoc),my PC can ping to each other(same as utp caple),so,i hope labview can distinguish from wired and wireless by somethings.i dont know it,like as BT labview know is as wireless
Message 17 of 21
(4,183 Views)
Dear review my attached paper to see can you find some help...
Message 18 of 21
(4,152 Views)
that 's amazing.I saw your Screenshots of MP Wi-Fi application .So,was it programmed by labview? it looks like connectify sowfware.How can i creat it by labviewand use it to connect wify PC-PC?.Which toolskit or module sowfware i needs install?.Sorry for my annoyance,i am a junior and it make me get excited ,but i dont know how to start
thanks for your share and hope for your response soon
Message 19 of 21
(4,134 Views)
Hai friend in trying to send using bluetooth.. can u send me ur program ?
Sathish Kumar A
Certified LabVIEW Architect (CLA)
Message 20 of 21
(3,747 Views)
