Programmatically measure the difference between two channels
How to programmatically measure the difference between two channels on multiple channel waveform graph?
(3,322 Views)
A graph does not do math, so simply subtract the data going into it.
(3,320 Views)
Hope the input to the waveform graph is Array of Decimal Value, With that you can do any math operations Smiley Happy
if You still face issue try something by your own and share the code will help you to do.
(3,267 Views)
