Programmatically change window appearance
Hello together
I have a quite simple question: Is it possible to use the same subvi once to appear as dialog and once in default mode?
This should be settable during run time. I am sure, that there are one thousand ways to go around this problem in my application. However, I am also personally interested if this can be done.
Thanks for anyone who gives me advice
Woodi
Message 1 of 16
(7,422 Views)
Hi Woodi
Using property-nodes you can do a lot. Have a look at it..
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 16
(7,418 Views)
Hi Woodi,
here's a quick example and a pisture to show you the possibilities you have with a property node 😉
Hope this helps
Message Edité par TiTou le 04-13-2006 09:04 AM
Epictetus
Antoine Chalons
Message 3 of 16
(7,416 Views)
Hello TiTou
Thank's a lot for your Help. This is exactly what I want.
Now I can run a subvi in background with default settings, or the user can make some changes if the window appears as dialog.
Woodi
Message 4 of 16
(7,397 Views)
Salut TiTou
There has come up another question.
I can now previously decide wheter a subVi is run in background or comes up as dialog. In the first case, some parameters are calculated without user interaction, in the second case, the user can make some changes and influence the calculation. The general advantage is, that i can use the same vi. This works all fine.
But how can I access the data this subvi gives? Respectively give some values to the subvi?
I guess I have run into a tricky and silly situation. Of course I could use global variables or alternatively do it completely different, but even though I am interested going this way.
Have you got an idea?
Greetings
Woodi
Message 5 of 16
(7,391 Views)
You can wire it as a normal subvi. Just connect the controls and indicators to terminals and it works.
If you want it to work as dialog don't wire these connectors otherwise you can use it as subvi.
Using LV8.0
Message 6 of 16
(7,384 Views)
Woodi,
*** do you speak french or just a few words like "salut" Smiley Surprised ?? ***
Global variable are not the appropriate tool to pass data to a sub-VI even if they could do the job.
It is not clear for me if you only want to get output datas from the subVI or if you also want to input datas from the main VI and also waht kind of data will you have to transfer ? The best way might be different if it's a large 2D array of clusters or if it's just a boolean 😉
Here is an idea...
Epictetus
Antoine Chalons
Message 7 of 16
(7,382 Views)
As Becktho pointed, you don't necessarily have to run the VI dynamically... if you don't want it to show up just put the sub vi in the main vi and connect the inputs and outputs.
Epictetus
Antoine Chalons
Message 8 of 16
(7,378 Views)
Here's an example how I could imagine to do it - it's definitely not the best solution, but it shows you how you could do it.
Using LV8.0
Message 9 of 16
(7,373 Views)
TiTou - just by wiring the vi the job is not done. You have to set its appearence, so that it opens when called - the problem is, that it also opens if you use it as subvi which results in a short flicker of it.
Using LV8.0
Message 10 of 16
(7,372 Views)
