Runtime slow
Good morning, I have a doubt.
How can I speed up the execution process when an event structure have implemented?
Greetings.
Hugo Santos
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Message 1 of 9
(4,717 Views)
Hi Hugo,
If you post your Vi then we'll be able to give you some pointers.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
Message 2 of 9
(4,714 Views)
Thank you,
Attached my VI,
regards,
Hugo Santos
Hugo Santos
Message 3 of 9
(4,712 Views)
Accepted by topic author hugosantos
Your event structure is not implemented properly.
Also, you forgot to include the FGV.vi and your custom control.
Take a look at the LabVIEW Help, particularly the caveats for using Event Structures and the need to put Event Structures inside of while loops.
Message 4 of 9
(4,699 Views)
Thank you for your help.
The FGV is included in the project.
After checking in labview help, my doubts remain.
Could you send me a basic example that I can adapt my application?
regards,
Hugo Santos
Hugo Santos
Message 5 of 9
(4,691 Views)
Go to the NI example finder and type "Event" you will get lot of examples. It is not advised to use operations inside the event structure because if any of the Event takes time then you will not be able to handle the other controls in the FP and also it may hang your PC easily.
Message 6 of 9
(4,688 Views)
Since your event waits for your sub-vi it'd be alot easier to just drop the sub-vi in the event instead of using vi server. 🙂
//Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 9
(4,682 Views)
Thank you for your clarification.
I present another question in attached VI, I can not stop running through the button "stop".
Know how to say why?
regards,
Hugo Santos
Hugo Santos
Message 8 of 9
(4,672 Views)
Already solved, I added an event to stop.
Regards, Hugo Santos
Hugo Santos
Message 9 of 9
(4,668 Views)
