Problems when running Modbus Example from LabVIEW Modbus Library
I need to stablish communication between a computer and a PLC using Modbus RTU. First, I downloaded a modbus library for LabVIEW, version 8.2 ( ni_modbus8_2.exe )
The installation was all right. But when I try to run the MB Ethernet Example Slave.vi to pass data with MB Ethernet Example Master.vi, LabVIEW paralizes my computer with 99% CPU runtime. Even when I stop the VI, LabVIEW remains running at 99% and not responding anymore.
I don't know what I'm missing... This is a bug driver? I'm using a LabVIEW version 8.2.1 with DSC module.
Thanks a lot!
(5,930 Views)
Hi Klein,
When during the running of this program do you notice the CPU usage increase to these levels on your computer?  And to understand your set-up clearly, are you running the slave vi on your computer and the master vi on your PLC?  Also, do you notice this behavior on a computer to computer connection, or just when communicating between the computer and the PLC?
Anna M.
(4,262 Views)
