06-21-2007 12:21 PM
06-24-2007 09:59 PM
Hi JoyWang,
In order to use a DLL in LabVIEW you will need to use the call Library Function Node.vi to load the dll. You can pass the structure as a cluster but you will have to make sure the elements inside map to the proper data types in LabVIEW. This KnowledgeBase walks through how to pass a cluster to a dll from LabVIEW. I hope this helps you out.
