Problem with subVIs in executable
Yes but the problem is that I have that license...
Message 11 of 15
(1,655 Views)
I am not sure then maybe others can help. If it was for single PC then maybe you can't use for multiple PCs or something like that. Can you post your Screenshot of NI MAX and/or License manager showing that it is licensed?
uday
Message 12 of 15
(1,654 Views)
Do you have it installed on the target machine?
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 15
(1,632 Views)
Yes. But I think that is not the problem. Because EXE does not work in develop machine and I have installed in there...
However, to run a executable I read that only Run Time Engine is needed... is right?
Message 14 of 15
(1,629 Views)
OK, the errors seem to say that you are attempting to use an NI Product for which you do not have a valid License, i.e. you have not paid for it.  It also mentions LabVIEW Real-Time -- is it possible that you are trying to use a product designed for LabVIEW Real-Time, but are not running (or licensed for) LabVIEW Real-Time?  Is there another way to do what you need without using such an un-licensed Product?  Or, if you require this Product, can you afford the license?
If you do have a license for it, then contact LabVIEW Support for help in activating the license on your Development machine.  Depending on the product, you might also require licenses on the machines on which it will be deployed.
Message 15 of 15
(1,619 Views)
