Problem with sbRIO at first start
we got a problem with our new sbRIO's. If the sbRIO power supply is turned on and if you search for c-series modules you get the message "the session is invalid". If you try again it works and you could repeat it without a problem. But if you turn the power supply off and on again the will get the error again when you first try to detect the modules.
Also you get the message "the session is invalid" when you try to run the fpga VI for the first time after you turned on the power supply. After that there are no more problems.
So there must be some kind of problem with the network connection or the configuration of the sbRIO's.
Here some more information:
-the firewall is off
-the problem occures on both our sbRIO's
-with another NI 9024 there are no such problems with the fpga VI after the startup
Hope you can help me with this problem.
Greetings Marc
(5,627 Views)
Does this really happen because it's the first time, or because you do it directly after start up?
IIRC, the HW might need 10 seconds to get started. So, do you get the error when you wait 10 sec. and then do the search?
(5,518 Views)
Hi, please take a look at this knowledge base: http://digital.ni.com/public.nsf/allkb/B746EA10EA65BE894825733D006BEA8F
It should help.
(5,511 Views)
I tried both your suggestions but unfortunately neither helped with problem. I waited 3 min after power up and the error (session is invalid) is showing up again.
Also I increased the RPC Timeout values like stockson suggested it (doubled all the timeout values) but problem is still the same.
Any other suggestion how to solve this problem?
Many thanks
bominze
(5,496 Views)
Accepted by bominze
Are you using the newest LabVIEW and drivers?
Is the sbRIO connected to the PC via a router or switch?
Does the error appear if you connect a single sbRIO directly to the PC?
Does the error appear if you use static IP settings?
Can you ping the sbRIOs without issues?
(5,476 Views)
many thanks stockson, the solution was to use static ip's
(5,462 Views)
