Problem with com port when streaming data.
Sorry, I don’t have LabVIEW accessible right now, but I also used the latest vipm package. The code on GitHub definitely shows it to be there: https://github.com/rfporter/Modbus-Master/tree/master/MB_Master
Look in the MB_Master class under Properties>Slave ID.
Since it’s in a property definition folder, you could also use a property node instead of the VI.
The VI from the NI Modbus Library won’t do you any good since it belongs to a different class.
The password for the NI library is bestbus. It is only applied in the vip build and is listed in the VI package build spec on GitHub: https://github.com/NISystemsEngineering/LabVIEW-Modbus-API/blob/master/.vipb
Message 11 of 42
(1,067 Views)
Still having trouble getting labview modbus to run  fast enough. I tried most of the suggestions above including opening and closing the modbus session outside the loop but that in fact ran slower. using the propery node to change unit ID was slow. I tried the NI modbus library and eventually found the change unit ID vi for Plasmionique (it is in the library but the slave library doesnt show on my pallet) and this is my best result but it is still variably 3 or 4 readings per second when I want 10. I have tried it on labview 2014, 2020 and the latest community edition. I have changed laptop with a clean install of windows 10 pro, but no good. I have a similar program running on a windows 7 machine with Labview 2014 -works perfectly. Any more sugestions please before I go off and program it in python (another 12 months probably).
Message 12 of 42
(983 Views)
Hello EdHarris,
Since you mentioned COM Ports. About a month or two ago, Windows 10 and 11 changed some settings with their update. This affected my application with the COM ports. For me, that the solution was to look into the latency settings: (Changed it to 1ms from 16ms) (Update forced a 16ms value).
Maaybe your settings needs to be looked at as well. Worth a try before 12 month new project. Here is where is discussed my issue.
Message 13 of 42
(961 Views)
Hello Xonmyth, thanks for that suggestion the atency was at 16 on my pc also. I am now up to 6 or 7 readings per second. I have tried reducing the number of slaves polled, taken out the arduino slave from the bus but it makes little difference. Still looks like its going to have to be pyhon though.
Message 14 of 42
(940 Views)
ouch!
If you still want to entertain using-LabVIEW idea.
Couple more things. First, I think you will be achieve the desired result in LabVIEW. Second, I looked at your block diagram just now, it is a mile long and uses flat sequences, not optimal.
I have not worked with modbus but have worked with other communication methods and I can confirm that LabVIEW works reliably up to 5,000,000 baud, parallel reads from two devices, I have well tested it. But that require producer consumer architecture. I would strongly recommend considering implementing that now or in future.
What you have right now is an invitation to problems. Move your code from different flat frame sequence structures to different states (Use a state machine). Producer loop will handle time sensitive part (i.e., Read and Write). Consumer will handle processing of the data you read (Buffered). Channels can be use to transfer data between producer to consumer loop (for less complexity).
Ensure wait times between each iteration safely allows you maintain desired read rate or functionality and does not cause any buffer overruns while not being too greedy for resources.
Edit: it will look something like this:
I can add more details but writing all this made me think, you might be more comfortable with python.
Message 15 of 42
(914 Views)
Good idea Xonmyth, but a big job, at least with the flat timing I can easily understand the sequence of processes and I did test just the data aquisition loop on its own which showed all the other stuff wasnt the problem. I think I will try upping the baud rate again, although its a pain changing it on all my different slaves.
Incidentally it seemed when I did this before the timing issue went away but then returned - perhaps when the program recompiled. Any ideas if that hunch is a possibility and what might be behind it?
Message 16 of 42
(872 Views)
Hi EdHarris,
I took a look at your code today and like @  suggested, I think the problem is opening and closing of Modbus session with each iteration.I have not worked with MODBUS but following some LabVIEW programming standards, I think you need something like this:
With many assumptions, I have modified the Beamex Streaming.vi that draws parallels to your code so that you can follow along. Eventually, you would want all of this in a nice state machine for better control and reliability. Modifications I made are to show the concept. You may need to further modify it to meet your exact requirements.
Please see my questions and notes in the VI as well.
X
Message 17 of 42
(838 Views)
It is surprising that you found opening and closing the modbus session outside the loop ran slower, which contradicts intuition and my benchmark results below, so it would be interesting to see your code where you attempted this.
I developed a simple benchmark VI with a modbus device using Plasmionique Modbus Master and found that opening and closing the modbus session outside the loop reduced the loop iteration interval from 288ms to 32ms.
It you'd like to try my benchmark code, here it is as a VI snippet (you'll have to change the port, serial config, etc, to match your device). It may be useful because it isolates the read holding register function to show how much that one aspect is limiting performance.
Message 18 of 42
(807 Views)
Hi Xonmyth, Thats a great help to start me off, thanks. I am trying to apply it to the Beam4 Plas VI (posted in message 12) where the real problem exists. One issue is that the first slave data is formatted differently than the others so I am wondering if I should pass it to the write data vi and then process it?
As you asked in the notes of your snippet, what I am doing with the timing is record the time from the server before and after doing 3000 reading sequences. Then that is printed to file at the end of the readings. I do that so that the timing and data are easily associated with one another in the file. That process happens 24 times then I go back and make other changes and collect other data before doing the reading cycles again.
All I want is the data but I have been set back 18 months (part time) trying to make an arduino into a slave and make an amplifier to get data from a geophone. In the end I realised I2C is Fing slow so I got an arduino with a higher resolution ADC built in and stuck with modbus for everything. Thats working fantastically well now just have the labview side to sort.
Message 19 of 42
(786 Views)
It will still follow the same concept as I shared. I might be able to explain better with some mock up VI to get the idea across once I get the access to my PC with LabVIEW.
Message 20 of 42
(760 Views)
