Problem with Compumotor 6400 and Labview
A colleague and myself have been trying to get a compumotor AT6400
card working on an NT4 system (SP6) running Labview 5.1. We took it
out of an old machine due to a fault with the motherboard and hard
drive. This meant we had to re-install Labview, and now we're having a
problem running the vi's that we copied from the original hard drive.
The problem appears to be with the vi files directly associated with
the 6400 card. When the main program is run, it tries to load certain
files. One of these files is called 'devcom.llb'. When we try to open
this library, it comes up with the following error message:
'Error whilst trying to open labview\vi.lib\motion\devcom.llb'
Then when we click 'ignore' we get a windows exception error.
Are we
correct in thinking that we need to find and install something called
'Motion Toolbox 6000'? If not, does anyone have any ideas as to what
the problem could be?
Many thanks,
Ben
(2,655 Views)
I don't remeber asking this question!
Sounds like an install order issue.
De-install all software.
Install LV
Install motion (make sure support for LV is selected)
Try again.
Ben
(2,655 Views)
