Troubles using while loops and case loops
Hi, i have accounted a lot of problems using labview 6.02 with field point. My main problem was that originally i had trouble running two while loops at once and been able to control them independently e.g. start and stop each loop when i want, but i have also come up with a separate problem. when using case loops with while loops, i can not seem to to get them to work properly. Like say if i have a program with while loops and i want to switch something on and off using a case loop its not possible. An example of this are below, any help greatly appreciated.
Thanks Stuart
(2,735 Views)
Sorry could not stop this one being posted, the example is on the second one.
Stu
(2,735 Views)
