Problem nesting combo boxes between them LabVIEW
it's file name, the file is like NAM1_ATP5_Environnement2_FT3_Signal7_Reptopo. We'll have a drop-down menu when I click on NAM, there will be all the files with the registered NAM, as soon as we select this NAM, there will be several ATPs and so on
Message 21 of 30
(1,015 Views)
Hi Problem,
@Problem LabVIEW wrote:
Message 7 solution doesn't meet my expectations because NAMs are pre-filled and I want it to be dynamic
Please re-read message #7!
Then implement step 1 and 2…
Message 22 of 30
(1,000 Views)
Should be LV2018 now.
Qestit Systems
Certified-LabVIEW-Developer
Message 23 of 30
(945 Views)
Hello, via a friend I managed to have it in version 2018, thank you, I am working on your code. I wanted to know how you were doing so that your combo box 2 depends on your combo box because the problem is that the values of the drop-down menu that offers this code are frozen data.
Thank for your help.
Message 24 of 30
(935 Views)
Hi Problem,
the example VI uses an INI file to define the content of "Combo box" and "combo box 2": did you provide such an INI file with some (correct) settings?
Otherwise see message #7 and mplement steps 1 and 2 to replace those INI file functions…
Message 25 of 30
(921 Views)
Hello everyone,
compared to all the indications that there has been on the topic, I put to you the VI unfortunately there are errors. I wanted to know if I'm finished soon or not, if yes is there someone to start me so we can have a finished VI. Thank you to the people who are contributing.
Message 26 of 30
(788 Views)
Accepted by Problem LabVIEW
Here is something that works. I cleaned it up a little, but not much. You will still need to remove duplicates from the arrays of strings and turn off Allow Undefined Strings on each of the combo boxes.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 27 of 30
(778 Views)
Thank you for correcting my VI, but I wanted to know if I could have the SubVI that you use to make the code functional. Thank you for your help I'm moving forward with my project, thank you.
Message 28 of 30
(730 Views)
It is called Delimited String to 1D String Array and it should come installed with LabVIEW. This is all it is:
Redhawk
Message 29 of 30
(725 Views)
thanks you for the help i finished my code
Message 30 of 30
(690 Views)
