How to slove this
I downloaded labview using the serial number given by the school.Halfway through downloading, this message always appears.I've been trying to solve it for days, but nothing works
Message 1 of 12
(1,048 Views)
When students came to ask me if they could install LabVIEW on their laptops, I always answered "Yes, but ..." and asked them to bring their laptops to me and let me do the installation for them.  After several hundred LabVIEW installations, I've learned some "tricks" to how to do it without (too many) problems.
It looks (from your Error Message) that you chose to install the MGI package mentioned on the last set of "Additional Items" (I'm not certain this is the correct name, but it's the section of NIPM after you choose LabVIEW and Drivers).  Simply don't choose to install this package!  If it turns out you find out you need it, then it is also available through the VI Package Manager (VIPM), which you should have installed on the first "page" of the NIPM-based LabVIEW installation.
Message 2 of 12
(1,024 Views)
When I uncheck mgi solution explorer, labview can be installed successfully and I can find it in the search field, but I can't find it in the windows application and I can't open it. I don't know if there is a bug.
Message 3 of 12
(983 Views)
I assume with "it" you mean LabVIEW and if you can find it in the search field (as you said!), you should be able to run in right there.
Can you explain what you mean by "can't find it in the windows application"? (since the community edition is a 32bit application, it will be in the "C:\Program Files (x86)" hierarchy, on 64bit windows, right).
Message 4 of 12
(955 Views)
There's a lot we don't know about your setup (@altenbach's response reminds me that I didn't ask you about what you are installing).  So here are some questions and suggestions, and how to get MGI Solution Explorer.
  • You mention "the serial number given by the school".  I assume you went to the NI LabVIEW Download site, and tried to download and install LabVIEW.  Were you given any instructions on how to do this?  How to specify the version that you want?  Whether to get 32-bit or 64-bit?  Which edition (Base, Full, etc.)?
  • If your school has an Academic Account with NI, your IT department should be able to tell you how to download the Academic version of LabVIEW, for which you'll need the Academic License key for your school.
  • There is also a Community Edition of LabVIEW.  This can't be used for teaching or research at a school, but if you are learning LabVIEW and want to "practice at home", that is probably allowed (go on the Web and look up "LabVIEW Community Edition").
  • If you have LabVIEW installed, and want to get MGI Solution Explorer, Google (or Edge, or Firefox, or Safari) is your friend.  Type "MGI Solution Explorer" in your search bar and hit <Return>.
Message 5 of 12
(950 Views)
As shown in the picture.It shows up in the search bar but when I click on windows>setting>application and then search for labview it doesn't show up.I downloaded the 64-bit version and then used the serial number given by the school to activate it.
Message 6 of 12
(943 Views)
It is installed via the "NI package manager", so only that will show up under installed application. This is normal. To uninstall, you would run the NI package manager and to run LabVIEW just click on the yellow icon in the search..
Message 7 of 12
(938 Views)
When I click on it , nothing happens
Message 8 of 12
(935 Views)
I also tried starting it as an administrator, but nothing happened.
Message 9 of 12
(934 Views)
Are you running any unusual antivirus or other security software? Does anything show in the task manager? How about the system logs?
Message 10 of 12
(929 Views)
