Problem in using two separate 3D parametric plot windows
I one application I have two activeX windows for 3D parametric plots. Sometimes I notice a data leackage between the graphs (and usually just one point, like in the figure I inserted). But I have cheked the code, everithing seems to be ok. they are totally independent.
Did anyone also experienced such a problem and how would you recommend to eliminate it?
Thanks in advance
Edgar
(3,181 Views)
I have seen issues with the 3D plot bleeding through from a hidden tab page. That was logged as a bug and I beilve they are working on that one.
Ben
(3,173 Views)
Exactly, I have also placed them in tab.
(3,168 Views)
Then my work-around was to hide the ActiveX container (visable = False) when not viewing that tab page.
You would have to check with NI to find out when they are planning to fix that one.
Ben
(3,156 Views)
