Problem getting correct graph data
OK, stop the program right after error occures and post this NI SPY log
Message 11 of 20
(2,791 Views)
OK, the now the program stops when it gets an error.
In attachment: spy file, program
Thanks a lot for your time,
Thomas V.
Message 12 of 20
(2,788 Views)
Is your VISA timeout wiat time less than your sweep time?
If possible, I always use some form of the OPC command (usually *OPC? because it's so easy to implement), and make the VISA timeout > longest sweep time.
Bill
CLD
(Mid-Level minion.)
Message 13 of 20
(2,765 Views)
If the failure occurs, what do you see on the instrument screen? Can you see the correct trace data?
Message 14 of 20
(2,749 Views)
Yes, when the query interrupted occurs, the traces on the device are projected correctly.
I looked at the raw data we get from the ZVL and 80% of the time the values are correct, the other 20% the values are false.
Message 15 of 20
(2,743 Views)
It seems to be firmware related problem, I discussed it with development engineer. You're running FW 3.20 version, try to get the new 3.21 from R&S page:
http://www.rohde-schwarz.de/de/Produkte/messtechnik-testsysteme/netzwerk-analysatoren/ZVL13-|-Firmware-|-23-|-2584.html
Message 16 of 20
(2,729 Views)
Ok thank you,
but the link you provided doesn't work, it says the page doesn't exist when I try to open it. Also tried searching for FW3.21 on the site but it gives 0 results.
Message 17 of 20
(2,719 Views)
edit: the link works
Message 18 of 20
(2,712 Views)
we've updated the drivers, but the problem is still here. Query interupted error and weird graphs.
Message 19 of 20
(2,709 Views)
Accepted by topic author Thomas_V
You will have to live with the reading the trace again on these ocasions. Fixing instrument FW will take some time. Use rszvl Clear Instrument Errors.vi from Utility group to clear this error from the instrument queue.
Message 20 of 20
(2,705 Views)
