Problem counter (Frequency)
I have a DAQ card 6024E. I want to measure a frequency between 10 and 500Hz, (from a propeller) approximately. The signal come from a inductive-sensor. When I put the signal on the PFI9 input (ctr0 gate) and I use the DAQmx "CI Frequency" (1 counter measure) I get sometimes good measure and sometimes wrong measure (0,3 Hz or 2MHz for example).
So, Please you can help me, where is the problem?
Franco
this is mi VI
(3,563 Views)
Problem counter is nice , I stopped counting them 😉
How does your sensor output signal look like?  Read it with a scope or your card (set at max sample rate) .
Then take a look into the spec of your card if the output match the counter input spec.
at least you can read the output with an analog channel ( add maybe some filter) and do a tone measurement.....
Greetings from Germany
Henrik
LV since v3.1
(3,544 Views)
I already answered to your question on the french forum but I also answer here for english people who have the same problem.
There are a few problems in your VI. The detailed help specifies that you don't need to connect the divisor input when you choose Large Range with 2 Counters in the measurement method of DAQmx Create Channel (CI-Frequency). Moreover, you don't need the DAQmx Timing (Implicit) function in your VI. However, you'd better add a Wait Until Next ms Multiple in your while loops in order to avoid a processor overload which would slow down your computer.
So I changed a few things in your VI. Please find it in attachement. I saved him in LabVIEW 2009.
Please let us know if you succeed to read your frequency measurements.
Jérémy C.
NI France
(3,530 Views)
thank you very much, I sent you a message asking for the VI in labview2009, in the french forum, sorry
thanks
(3,525 Views)
