Printing a File(.html, .doc ,etc) from LabVIEW
Hi elyan,
i don´t know what you make with this vi (print2.vi). Where do you call it?
Mike
Message 11 of 14
(1,595 Views)
Hi mike
fist of all thanks
attach see file please ,,, please run print .vi ... then pleae press on save button , this will create file which called demo.html at c:
from here the problem began  ,,, i want to load " call"  the file and  print it .. i don't know how to fixed the problem  ,,
thanks
Message 12 of 14
(1,591 Views)
Hi elyan,
you can´t use the print2.vi in this vi, because your conencted reference is not valid. I think you don´t need the type, because you already know that you want to print a html page. Change the code as shown in the picture.
Mike
Message Edited by MikeS81 on 07-17-2008 02:46 PM
Message 13 of 14
(1,590 Views)
thanks its working
Message 14 of 14
(1,576 Views)
