Printer GX430t
i want to know how to install and connect the printer GX430t .
i connect the printer with USB .
i do not find the printer in NI MAX .
Can any one help me  please .
(4,937 Views)
Sometime back I had tried to connect other type of Zebra printer through USB, but it didn't workout.  I ended up using simple serial COM to communicate with printer ZPL commands.
Useful links.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019WlfSAE&l=en-IE
http://labelary.com
https://www.zebra.com/content/dam/zebra/manuals/printers/common/programming/zpl-zbi2-pm-en.pdf
Ajay MV
(4,919 Views)
Accepted by Emna20
Here is a USB driver that works with Zebra printers. This code is posted "as is". The dll included in the ZIP should be copied to the folder "c:\ProgramData\Zebra Tools\Drivers". There is a known issue with this code if you are trying to communicate with more than one printer at the same time. There is a possibility of cross talk. This only occurs if the communications are at the same time. If communicating with a single printer, though multiple are connected, everything works fine.
I should add that the most efficient way to send labels to the printer is to use the native ZPL formatting language. This also makes data updates to the labels, such as serial number or other variabkle data, very easy using basic string functions.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,877 Views)
Hi  ,
i couldn't open your Zip files.
thank you.
(4,820 Views)
They opened fine for me.
What specific error message did you see when you tried to open them?
(4,809 Views)
It would be helpful to know what problem you are having.
Mark Yedinak
LabVIEW Champion
(4,807 Views)
Hi  ,
now every thing work fine thank you very much.
(4,804 Views)
