Polar plot to 3D graph
Hello
I need create 3D graph. I have polar graph and this polar graph (polar graph.jpg) I need trasform to 3D graph, but I have matrix 18x36 data. 36 is from 0 degree to 180 degree every 5 degree and 18 is count polar graphs. So I need this all polar graphs put to 3D graph, but this is problem. This polar graphs I need to rotate 10 degrees in X Y axis I mean (example.jpg). In (direction.jpg) is direction drawing polar plot.
I did it by this example https://forums.ni.com/t5/LabVIEW/Antenna-Radiation-Pattern-in-3D/td-p/2886874/page/3 but it is bad for me (my 3D.jpg).
Thanks for every answer
Message 1 of 18
(6,912 Views)
will be better if you upload sample of your data and vi (for LabVIEW not more than 2016)
Message 2 of 18
(6,858 Views)
okay, data are (I18.zip) and VI for parse from data to graphs
Message 3 of 18
(6,855 Views)
Hi!
I have done brief research and found these two articles:
Plotting Arrays of XYZ Data Using the 3D Surface Graph
Plotting Data on 3D Graphs.
Hope they are helpful!
Happy Holidays!
Message 4 of 18
(6,837 Views)
Dont work, because error (error.jpg)
Message 5 of 18
(6,820 Views)
@Ahoj123 wrote:
Hello
 do you want to rotate a point in three-dimensional space about an arbitrary axis?
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/coordinate-llb/3d-cartesia...
Message 6 of 18
(6,812 Views)
Thanks for your answer and for all answers.
Please Can you give me some examples? I mean VI for all rotation Z, X', Z'. I find too https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/coordinate-llb/3d-cartesia...
and this is for direction ploting polar plot? in my picture (direction.jpg)
I need rotate about Z axis. Maybe? (first picture, right). In first post are pictures how I need rotate.
Thanks for every answer you are best 🙂
Message 7 of 18
(6,805 Views)
the link I posted is meant to be used with the "3d picture control", which is quite different from the 3d surface plots you use in graphs.vi ‏48 KB
an use case example of "3d cartesian coord rotation" can be found in the vi posted by MarcDub:
https://forums.ni.com/t5/LabVIEW/Rotations-in-3D-picture-control/m-p/3234120#M940881
Message 8 of 18
(6,776 Views)
Accepted by topic author Ahoj123
honestly, I don't understand what you want to do - is this a   a functional issue - or rather an cosmetic issue?
 I guess we are talking about this section of your code (which I did tidy up, see attached 2018-10-30_graphs.vi):
you have this dataset (2d z-array created from I18.zip ‏15154 KB using the unchanged rest of your code)
and you want to plot it on a sphere.
therefore you create an additional  2d x-array and an additional 2d y-array
and plot it together with the 2d z-array to "plot parametric",
and set the 3d plot's coordinate system  to "spheric"
do you want to rotate the whole "plot parametric" around the z-axis, because it looks nicer?
or do you think, something is not working properly?
by the way, you should right-click on "path2" and configure the control like this, as you don't want to selcet a a single file
but rather a folder containing a bunch of files
Message 9 of 18
(6,764 Views)
I am sorry for late answer. I am trying this and make 3D graph for me. I created four 3d surface with Z axis 2D array and four 3D surface with Z axis 1D array. Every 3d surface was another because I changed X Y and Z. Combine every with every. I change too degrees from 0-180 to -90 to 90. In picture is what I thought.
Thanks for your answer you help me 🙂 🙂 🙂
So I need help with 3D graph. I need set cursor in 3D graph with mouse. When I click with mouse to 3D surface or another 3D graph I need get position X Y and Z point.
How to make this? I find cursor in 3D graph properties but I can only set X Y Z in this properties but not with mouse. 😞
Message 10 of 18
(6,626 Views)
