Plotting XY graph with two values and time
Here's how the modification should look like (left). Alternatively, you could also read all lines directly (right-click the file read and select "read lines" and wire a -1 to the count terminal) (right).
Message 31 of 55
(1,415 Views)
I did do that initially but got the same error so i tried something different.
Iv'e attached the original files.
Message 32 of 55
(1,410 Views)
Well, these files have a completely different data structure and contain significantly more data per line.. You need to adjust the scanning operation dramatically.
Message 33 of 55
(1,406 Views)
Is it just the format string that needs adjusting or will other parts need to be changed?
Message 34 of 55
(1,395 Views)
My FOR loops process one line at a time. Your lines are 10x longer and much more complicated. You need to adjust the scan format to get the right data. Use my draft as a template.
Message 35 of 55
(1,387 Views)
It says I have used too many format specifiers, do I need to wire more default value terminals to account for this?
Message 36 of 55
(1,378 Views)
Nevermind its working now.
What is the input parameter for # ?
Message 37 of 55
(1,373 Views)
You probably need to be more specific that that. 😉
Message 38 of 55
(1,370 Views)
Well one of the spreadsheet cells contain ###, so I need to specify this in the string function.
Message 39 of 55
(1,362 Views)
Are you sure the width of the cell is large enough to hold the value. Excel will fill it in with # signs if the cell is too small.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 40 of 55
(1,356 Views)
