Plotting Types
Hello everyone,
Am trying to plot graphs in the following style and type.
I need details about doing the same in LabVIEW.
Glad, if anyone helps..
You can't help everyone, but everyone can help someone Smiley Wink
Message 1 of 10
(6,051 Views)
Accepted by PriyadarsiniS
Hi Priyardarsini,
the left one looks like an error bar plot, the right like an ordinary waveform graph…
Message 2 of 10
(6,041 Views)
The graph on the left is tricky.
I would utilise the picture control lay over that is build in in most LV graphs. There might be a learning curve, you need to get familiar with picture controls, and graph events. Benefit is you get the graphs scaling for free.
Depending on the exact case, I might skip the graph and use only a picture control. You can do everything, but you need to do everything from 0... Drawing scales are very difficult.
Message 3 of 10
(6,015 Views)
The best way to do this in LabVIEW is use the "Advanced Plotting Toolkit" from Heliosphere.  Its available free in VIPM.
https://forums.ni.com/t5/Advanced-Plotting-Toolkit/gp-p/5004
The example they provide is a scatter plot but easy enough to make it a line plot with error bars.
The underlying plotting engine is MatplotLib, so anything it can do APT can do..just about.
Message 4 of 10
(5,996 Views)
Didn't know about that toolkit. No interaction (zooming, moving, etc. like a LV graph) though.
Message 5 of 10
(5,989 Views)
True. It mainly allows you to make prettier plots and more advanced plots without any effort, but at the cost some common LabVIEW plot features.
There's documentation here - http://advancedplotting.github.io/
and examples here - http://advancedplotting.github.io/docs/index.html
Message 6 of 10
(5,976 Views)
The resource 'Advanced plotting toolkit' looks like a simpler and made easy tool... Thanks anyway for introducing such tool..
My opinion on these plots is that, it looks fine on the error bar or feather graph even through default library functions of NI...what matters is the auto-scaling of axis that determines the readability and more scaling processes.
Third party in this case is further adding up-to risks with complexity, and I feel like its unnecessary in this case.
Message 7 of 10
(5,941 Views)
Check out this presentation I did at NIDays and an advanced UG meeting 2011\2012. Haven't looked at is since, you'd be the first in 5 years!
It shows how to use the picture control inside graphs. You'll have the best of two worlds.
Note that the code is crap. Hardly any sub VI's, on purpose. The code is mend to demonstrate the technique, and nice code tends to hide these details. I'd go for a class, since this particular situation is very well suited for OO.
Message 8 of 10
(5,926 Views)
Thanks for sharing!  Interesting stuff.
Message 9 of 10
(5,883 Views)
Thanks! It seems to be an eye opener even for seasoned LV programmers. You'll never notice these overlays if you're not looking for them...
Message 10 of 10
(5,865 Views)
