Plot a curve on an xy graph with an equation
I need to plot several curves on an xy graph.
I know how to plot multiple curves I just don't know how to do it with an equation.
example    y=2.039+1.116*exp(.01468*x)
I did this with point to point manually, but will have many of these with plus and minus also.
So plotting with an equation would save alot of time.
Message 1 of 8
(12,828 Views)
Accepted by RedneckNerd
Hey,
I'm not sure if I get your problem correctly, but you can do all kind of maths with arrays as well (even for example multiple an array with a single number or another array) and you can bundle them to be plotted on xy graphs.
For example in this snippet (you can copy this image to the block diagram and use the code from it) I use the for loop to give an array to be the x axis (you can use your existing x axis data in an array) and then I do several mathematics on it: first I do your formula to calculate y data, secondly I do a truncated version of your formula to get another set of y data and lastly I use a mathscript node to get the same data as the first one (although with slower performance, especially if you use many formulas as primitives give much better performance than mathscript). Then I bundle them into clusters and build an array of them to plot all of them
Then the result is this with plot 0 hiding plot 2 as both have the same data.
I hope you were looking for some help like this.
__________________
Engage! using LV2015
Message 2 of 8
(12,815 Views)
Create an x-ramp and then apply the formula to calculate the y-values. Bundle the two for a plot. If all plots share the same x-values, you only need to create the ramp once.
Message 3 of 8
(12,813 Views)
jeanlucpicard This worked perfectly thanks.
The bundling of the data and using the for loop is exactly what I was looking for.
Message 4 of 8
(12,767 Views)
I'm glad I could help. However, if you need an x-axis with a sub-1 resolution (i.e. with decimal values) you might want to use the ramp as altenbach suggested instead of the for loop
__________________
Message 5 of 8
(12,758 Views)
Currently i don't need sub one yet, but it will come.
Is the x-ramp just math inside of the for loop or is it a function?
Message 6 of 8
(12,750 Views)
There is "ramp pattern" in the signal processing...signal generation palette. Just give it start, end, and number of points.
Message 7 of 8
(12,747 Views)
Thanks.  This also helped me to find another vi I have been looking for!
Message 8 of 8
(12,744 Views)
