Pixelmap or image from 3D control?
      How can I grab the current 2D view from a 3D control, as a Picture, pixmap, or image-type?
Thanks!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(6,549 Views)
You can use the 3D picture control "Render to Image" method. This method returns an image of the scene.
Tunde
(6,514 Views)
And for another twist see reply #7 in this thread
where Marcus teaches us how to insert the 3d graph in a PowerPoint presentation. He recieved 18 5-star ratings for that one.
Ben
(6,508 Views)
Dear Tunde and Ben,
      GREAT!  while it's Tunde's solution that I needed...
Ben
.. it was fun to bump Marcus's post - which currently stands at 20/5.0!
Cheers!
(6,497 Views)
Doh!  Sorry Tunde, I don't see a 3D picture control - only 3D graphs (which don't provide a "Render to image" method.)
I'm using 7.1 "Full" maybe that's why I'm not seeing the 3D picture control(?)
Graphs do have an Image property - but it's a "Picture" reference (the wire is teal colored, not blue!)  This "Picture" reference has a "render" method, but that exposes only scalers - 6 or so.  The 3DGraph's Picture-reference also has a "Handle" attribute, but that's another dead-end without more info.
I would like to automate the extraction of the image (or pixlemap) for a 3D Graph control!
BTW Tunde, you're BLUE!?  How'd you do that?
Cheers!
Message Edited by tbd on 03-03-2007 12:42 AM
(6,493 Views)
`Hi TBD,
That can be a little confusing the first time you run into into it.
The reference that LV creates on the BD when you drop a 3-d graph is a reference to the CW 3-d graph that runs inside an ActiveX conatiner.
Got to the FP and right-click on the freame of the 3-d graph and do a "create reference" (or invoke node) and you will get reference to the ActiveX container.
If you get a chance post an example.
Have fun!
Ben
Message Edited by Ben on 03-03-2007 08:39 AM
(6,488 Views)
Quite right - I didn't realize the FP control and diagram terminal referred to [slightly] different objects. Smiley Surprised
Well, I'm not sure what you might be expecting, but here's a GIF built from one of LabVIEW's 3D Examples.
Also attached is the GIF writer - which may be available at OpenG (under Picture lib.)
Cheers!
(and have fun  Smiley Wink - )
Message Edited by tbd on 03-04-2007 03:21 AM
(6,469 Views)
