sms error
hi...i am trying to send sms using labview.finally i get one example from ni site..
but i have problem to run this .vi file..the error exist..i am using LV 7.1..could anyone help me to solve this problem..
thannks...
(2,696 Views)
I can't look at the VI, but the error means that the server refused the connection (as it says in the bottom part). This might be because you're trying to use a server which does not listen at the port the VI is using.
Make sure you're using a valid mail server and port (look at the settings for the email program you use to see valid settings).
___________________
Try to take over the world!
(2,691 Views)
