Peak detection with automatic threshold handling
Hi
for my experiment I need to find out multiple peaks  and valleys but every time data changes so setting up threshold manually is difficult. Please help me in finding threshold automatically.
Prashant Soni
LabVIEW Engineer
Message 1 of 8
(4,250 Views)
Consult a terrain map to locate multiple peaks and valleys.  If this is a LabVIEW question, maybe you could elaborate some and upload any code you are having trouble with.
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(4,222 Views)
You could try to normalise the data before detecting peaks. For instance, scale the data to 0 to 1 (subtract min, divide by max-min) or -1 to 1 (as before but X2-1). Or scale so the mean is 0 (get mean and subtract it) and divide by spread or stddev.
This might not work, good peak detection is an art. It's very dependant on the exact situation.
Message 3 of 8
(4,192 Views)
Or make a histogram. The highest peak in the histogram is often (it depends) the noise level. Base the threshold on that.
Message 4 of 8
(4,189 Views)
Read the help on the peak detection vi.
It will fit a square function on your data over point length. So depending on what you are looking for you migth need some interations ..
If you post some example data and a more detailed description of the points you are looking for more detailed help is possible.
Greetings from Germany
Henrik
LV since v3.1
Message 5 of 8
(4,184 Views)
I agree. There is no "one size fits all" way to find the peaks in data. It all depends what your data looks like.
Here is some typical data that I run into quite often. I can't think of an "easy" way to detect the 10 peaks that are above the noise floor in this spectrum. By setting the threshold too high, you risk missing the lower peaks. Set it too low and you get a lot of false positives from the noise floor.
As Henrik said, we can't help you unless you post some typical data.
Message 6 of 8
(4,170 Views)
A high pass ? 🙂
Henrik
LV since v3.1
Message 7 of 8
(4,153 Views)
I agree, a highpass filter would work. But I think jamiva was just making a point, not asking a question. Point would be: this needs a high pass filter, other situations need other solutions... So we need details to make specific recommendations.
Message 8 of 8
(4,145 Views)
