07-25-2013 06:05 PM
@alexderjuengere wrote:
attach your vi wrapped in a .zip file!
I can't attach any files at all - but I can insert an image. Not sure what's up with my browser.
07-25-2013 06:07 PM
The express filter VI is set to a rectangular 20 sample window.
The while loop subtracts the mean from 300-sample chunks of the signal until it reaches the end of the data. Doing this prevents the filter startup effects and facilitates thresholding, etc.
07-26-2013 12:33 PM
Hey Todd,
Your code worked great for the pre-recorded data, but I tried to use it for live data and it still isn't working. It seems like it fails to count the peaks most of the time. It will display an HR of approximately 12-15 BPM before slowly decreasing to about 2 BPM, even if your HR speeds up during that time. I may have made a mistake with the code, but I'm not sure where. Do you have any idea what could cause that problem?
Thank you again!
07-26-2013 12:38 PM
For example, there are pretty clear peaks here, but I still can't get a functioning peak detector
07-26-2013 12:59 PM
You could try changing Max and Min's "Sample Length" and Peak Detector's "Width" inputs to controls. Run it for a while and try different values.
07-26-2013 02:02 PM
I noticed that the "tick count" outside of the loop doesn't initiate in my live feed, but it does for the pre-recorded data. This could be why the displayed HR is constantly decreasing. Did you configure your "tick count" in any special way?
07-26-2013 02:12 PM
Sorry, ignore my previous question! I didn't have a shift register wiring the tick coutner into my loop. Now I'm gettign (mostly) accurate HR readings, and I can just mess with the widths.
Thank you so much Todd! You were EXTREMELY helpful!
07-26-2013 02:14 PM - edited 07-26-2013 02:14 PM
No worries. Welcome!
11-25-2014 06:49 PM
hi, can you upload the solution file for Labview 2010, please?
