Peak Detect
Accepted by Cleisthenes
A filter helps. There's probably a better implementation, but this might be a step forward:
Message 11 of 29
(3,352 Views)
That does look a lot better! What exactly did you do?
And would you mind attaching your VI? It'd be really helpful to take a closer look
Message 12 of 29
(3,347 Views)
Ah, I forgot to mention: that image has the code in it. Save it to your PC, then drag it onto a block diagram.
Message 13 of 29
(3,342 Views)
Do you save it as a .png? I seem to be having some trouble getting it over
Message 14 of 29
(3,336 Views)
Right-click on the picture. Select "Save Picture as". It should already be a png.
Then create a new, blank VI and open the block diagram. Drag the png file from the folder onto the BD.
I'd attach the VI, here, too - but somehow the browser won't let me, right now.
Message 15 of 29
(3,333 Views)
hi,
attach your vi wrapped in a .zip file!
Message 16 of 29
(3,328 Views)
Here's my take at a crude signal conditioning. With the relatively clean signal and zero mean the peak counting should be straigtforward.
Message 17 of 29
(3,325 Views)
Wow Todd, that's awesome! I've never seen that before.
Is there any way for the program to process live data, or does it have to be pre-recorded and stored?
Message 18 of 29
(3,310 Views)
Zwired, what exactly did you do to smooth out the signal?
Message 19 of 29
(3,308 Views)
It's called a snippet.
If you replace the for loop with your while loop and use the "Photocell Read" to supply the data instead of the Raw Data indexed values, you'll get calculations as you acquire data.
Message 20 of 29
(3,299 Views)
