le 02-08-2002 12:24 PM
le 02-12-2002 11:33 AM
le 02-13-2002 08:15 AM
le 12-14-2004 09:58 AM
le 12-15-2004 07:19 AM
le 01-12-2005 09:31 AM
le 01-12-2005 09:36 AM
le 01-12-2006 04:33 PM
My PXI-8146RT also has the same symptom as Tom. This occured while trying to upgrade NImotion to 7.2.
An attempt to do minimal installs didnt work and the controller is stuck in safe mode.
Has anyone fixed this problem by replacing the Flash drive with a larger capacity Flash?
If not, what is the remedy?
regards
frank
le 01-18-2006 06:23 PM
Hi Frank,
Do I understand you correctly in that your PXI-8146 was running OK until you updated NImotion?
I would like to hear more details of what went on in what order from the time it was working until it stopped.
Ben
le 01-18-2006 07:15 PM
