PWM using USB- 8451
I am using USB-8451 USB to SPI adapter to acquire data from a digital transducer and using DIO lines [0..5] to control solenoid valves.
My question is, if it's possible to generate PWM signal on those digital lines? If not, what USB hardware would you recommend? I have USB-6009. Would that work? How?
Thanks for your help!
(3,133 Views)
Hey ipc,
Check out this KB I found explaining how to use software-timed PWM with digital outputs.
Software-Timed PWM Using a Digital Output Line
http://digital.ni.com/public.nsf/allkb/1561D31534F07D608625727900391114
Hope that helps!
(3,112 Views)
