Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
05-01-2011 02:09 PM
Could anyone please help me to solve a problem with MAX.
I have recently installed labview 10 in windows 7 and tried to use the same labview code that I created using Labview 8.6 in Window XP.
This is the info about my task that I created in MAX:
Hardware : cDAQ NI 9172 (8 slots), one NI 9205, five NI 9219.
No of channel : 20
No channels in NI 9205: 13
No. Channel in 9219 : 7 (3 +4)
Sample to read : 100
Rate 1 kHz
The error in MAX: DAQ Assistant Error-200362 (onboard memory overflow ......some thing like that)
I am sure that the Labview program was working fine in my old operating system (XP) and Labview 8.6.
I read some discussions about the above error in the forum. There are some suggestions about the rate and sample to read.
Can anyone please suggest a rate and sample to read for my configuration.
Log
cou
05-02-2011 02:36 PM
Hi loges,
20 channels is a lot of channels to read. I would suggest increasing your # of samples to read. Due to software updates, the overhead required has changed from version to version and could be causing this error. Try changing the samples to read to 200, then 500, then 1000 and see if these changes make the error clear.
