PULSED RADAR
Hi everyone;
I want to make a simulator of pulsed Doppler radar [transmitter and receiver] using labview ,I am new on labview ,I will be grateful for anyone help me in this task.
thanks a lot
(5,220 Views)
Accepted by topic author ASHLY19
here we played around 😄
OK, mainly the display... the doppler signal processing part is 'just' some added math 😉
Greetings from Germany
Henrik
LV since v3.1
(5,186 Views)
Why the first project you want to do is a complex one?
Since your question is very wide, I'll try to help you to narrow down on the help we can provide.
What is the hardware do you want to use?
What is the distance and speed are you trying to monitor?
What precision?
Benoit
(5,157 Views)
thanks a lot bseguin: the hardware is USRP(2932) I want to build simple project on a place like a lab (range may be few meters speed may be in the range of [0.5 to 1] m/s
(5,135 Views)
Well you have a quite great hardware. I'm afraid that your solution will be in reading a lot of documentation. the learning curve might be a little slower than you wish, but the adventure will be great. 😉
Benoit
(5,123 Views)
can you help me to overtakes this task,if you have any documentations about this topic ,any idea about this,i will be grateful .
(5,101 Views)
