 ricmail85
			ricmail85
			04-28-2009 05:27 AM
I'm building a DAQ system as it follows:
The problem I noted is: when the waveform goes through the 0 value (for example a curve growing from -5 to +5), the program generates an error (I see it come from the VISA READ.vi). Instead, If the waveform's values are all positive or all negative, then the program doesn't report errors. Provisionally I'm working with only "half display" of the TDS (ie a all positive or all negative range); to do this, I introduced an OFFSET on the Amplitudes.
Can you help me?
Thanks.
 Dennis_Knutson
			Dennis_Knutson
			04-28-2009 08:54 AM
04-28-2009 10:44 AM - edited 04-28-2009 10:46 AM
thanks for the reply. Now I'm not at the University, but I remember the error was like to "error... scan from string". If you wont, I can send you my labview project. What do you think I have to do? However the scope acquired and triggered correctly. Thanks a lot!
 LiciaP
			LiciaP
			04-29-2009 03:05 AM
please let us know when possible the exact error code, which could be useful to understand the problem.
If I understood correctly, your VI is modified based on the driver examples; but do the original examples work correctly?
You may also consider this forum post.
Bye!
Licia
