sorting data
I want to sort the data from the table with accending order like
name                                         marks
John                                            50
mary                                            80
Cathrine                                      60
Thomas                                       67
Suzy                                            75                                                   to
name                                         marks
Cathrine                                      60
John                                            50
mary                                            80
Suzy                                            75
Thomas                                       67                                                  or
name                                         marks
mary                                            80
Suzy                                            75
Thomas                                       67
Cathrine                                      60
John                                            50...
I am a new in labview. Pls somebody kindly answer my question.
(4,230 Views)
Hi treasure,
are this arrays of different type. Build an array of cluster of your data and use the sort function from the array palette. See also this thread, it shows what i mean.
Mike
(4,226 Views)
See attached example.  I understood that you are using a Table.  Using an array (2D array) should also work the same way.
R
(4,205 Views)
That's what I want to do. Very nice and thank you for the quick reply.
Thank you Joe and Mike.
(4,201 Views)
can i have this example in labview 8.0...plz
(3,980 Views)
Hi jeyanthi,
here it is for LV80.
Mike
(3,977 Views)
Thank u Mike
(3,971 Views)
