PMT controlling
I am the one who are working with some PMT on a LED induced fluorescence setup.
Since, I am going to control the PMT using a DAQ card I need to some written ready to use LabView block diagrams. Is there anyone who can guide me in this regard?
Best,
(3,817 Views)
Hi Mahsa,
Since, I am going to control the PMT using a DAQ card I need …
Recommendation: when you write a message to get help you should explain "unusual" abbrevations like "PMT"…
Are you talking about a PhotoMultiplier Tube?
If yes:
  • Which type/manufacturer?
  • Does it come with a driver circuitry?
  • Does the manufacturer provide a manual for tube and driver?
  • Can you link the manual?
Btw. I don't think you are "the one"… 😄
(3,799 Views)
First, thank you for replying.
I'd be whatever you call, if you could guide me!😁
Yes, I was meaning exactly Photomultiplier Tube.
I have two options (H10682-210/ Hamamatsu, and MP-1982 (8674-P-0810)/ Perkin Elmer MP-1982) and there is no any driver circuitry with them, but I am not sure! Since they were order by other previous users which were working before me on my lab.
(3,790 Views)
Hi Mahsa,
both output TTL-compatible pulses, as can be read here and here.
You need to use a DAQ device with some (TTL-compatible) counter inputs!
(Btw. you don't "control" those tube, you just read their output signals…)
(3,786 Views)
Well, I have the DAQ card but for reading the output signal of PMT I need to use LabView and programming a block diagram to read my signal output. But since I am not that much familiar with LabView I need some written program at least, then I will change it more. Do you have some written codes to read these PMTs? and at the moment I do not have any clue with block diagraming in Labview.
(3,775 Views)
Accepted by MahsaGh
Hi Mahsa,
how did the previous student/engineer use those PMTs? How did (s)he create data files?
LabVIEW comes with a huge library of example VIs/projects: did you explore that?
Did you take the Training resources offered in the header of the LabVIEW board to learn LabVIEW?
(3,766 Views)
