PID
Hi!
I have a question, the gains of PID (Kp,td, ti) in MatlLab are the same used in LabVIEW?
They are found in Matlab and want to implement in labview with the PID of LabVIEW, thanks!
(4,083 Views)
Accepted by topic author Kelly.mg
Are you using the LabVIEW PID toolkit? If so, yes. The PID controller is a defined model for system control and should always be implemented the same way in whatever environment you are using them in.
_____________________________
- Cheers, Ed
(4,079 Views)
thanks 🙂
(4,075 Views)
